Old 02-03-2020, 02:18 PM
kevinw kevinw is offline
Default steering column
question
is it a large job to switch out steering columns on 69 floor shit Chevelle?
it has non tilt, and I was thinking of putting in a tilt from a similar GM car under 1979 due to splindal differences. but is this job pretty straightforward or a pain in the butt? thanks
Old 02-05-2020, 08:07 AM
Slick87gn's Avatar
Slick87gn Slick87gn is offline
Easy peasy. I did my column shift on my '70.
Old 02-06-2020, 06:58 PM
Not a bad job at all. I swapped a tilt column into my 72.
Old 02-11-2020, 10:38 AM
does it require taking off dash, how long did it take you to do it?
Old 02-13-2020, 07:18 AM
Slick87gn's Avatar
Dash stays put. A couple of hours for a first timer
Old 02-14-2020, 05:15 PM
ok, thanks for your help
Old 02-19-2020, 09:48 AM
As said, dash stays. Remove the hush panel under the column. Mostly plug and play. I didn't have any linkage to mess with, my car is a 4 speed manual.
Old 04-29-2020, 03:29 PM
question on this one again. what columns will work with the Chevelle? like, will C 3 corvette column work? or any others from like a impala or similar size GM car? thanks
Old 05-09-2020, 03:02 PM
I want to say you are stuck using a 68-75? GM A Body column.
Old 05-18-2020, 11:52 AM
ok thanks. appreciate it
