Old 12-13-2010, 06:28 PM
Warputer's Avatar
Warputer Warputer is offline
Unhappy She's down for the count.....till tomorrow I guess
Car has been loading up and sputtering on the take off for the past few weeks. This week has been worse, it'll cut off if you get in to it too much. Now it's in the garage, won't crank & smells flooded.....geez. Looks like a rebuild coming up.
Chris
69 4-Door Malibu
Old 12-13-2010, 06:48 PM
Sticky or misadjusted float? Good luck.
Old 12-13-2010, 07:22 PM
Warputer's Avatar
Thanks Hank....my local Holley expert is coming over tomorrow to give me some pointers.
Chris
69 4-Door Malibu
Old 12-20-2010, 03:22 AM
Warputer's Avatar
Found 2 seperate problems......#1 and the reason it died was the main power wire to the ignition had come loose. #2 was the bottom clamp that holds the distributor cap was loose, so the cap had rotated, throwing off the timing......that explains why it's been running rough for a while.
Chris
69 4-Door Malibu
Old 12-26-2010, 09:22 AM
Bdubya Bdubya is offline
Thats about as cheap as a fix that you can ask for!
