Old 08-25-2011, 02:05 PM
Rattler's Avatar
Rattler Rattler is offline
Default Smooth Firewall
Has anyone here smoothed their firewall? I've still got my motor out and decided I'm going to clean up the firewall before the motor goes back in. I've had the heater assembly gone for years now and it was just covered with a piece of aluminum screwed over the hole.
I cut out a piece of 16 gauge mild steel this past weekend and I'm planning on covering the entire passenger side so the firewall will be smoothed out. I'll post pics as I go along.
Old 08-25-2011, 03:52 PM
Actually sounds like a cool idea. I think it would look good.
Old 08-25-2011, 05:25 PM
earthquake68's Avatar
I've done it before. It goes a long way to clean up the looks under the hood. Clean all the seam sealer out of the joint and throw a few stitch welds in there to keep it tight before you mud over the seam.
Alan
1964 Chevelle SS
Old 08-25-2011, 06:29 PM
Rattler's Avatar
I've got everything stripped and out of the way
Here's the piece of metal I'm going to weld over the existing firewall.
Old 08-26-2011, 08:39 PM
That should look really nice when you're done.
Alan
1964 Chevelle SS
Old 08-28-2011, 05:29 PM
Rattler's Avatar
I had time to work on the car today. When I pulled off the passenger side fender I had a bolt rusted that decided to seize up in the nut so I had to cut it off to get the fender out of the way. Once the fender was gone I removed the door to get to the upper fender nut above the door hinge. After an hour or so of fighting with the broken piece I finally got it out and welded a new nut in it's place.
new fender nut welded in.
The next step was to get the new firewall piece tacked into place.
All welded up and ready for some grinding
And mostly ground down. Little bit of grinding and a small amount of body filler will be my next step.
Hopefully I can get some more work done in a couple weeks.
Old 08-28-2011, 06:14 PM
Like the saying,it's your car do what you want with him.
Old 08-29-2011, 08:27 AM
I'll be doing mine real soon... not completely sure if I'm going to do a whole new panel like that or just fill the holes.
Old 08-29-2011, 01:03 PM
The new panel is faster and easier, for sure. Unless you don't like the idea of two pieces of sheet metal laying up against one another. Then fill all the holes.
It looks great so far, Rattler.
Alan
1964 Chevelle SS
Old 08-29-2011, 01:42 PM
Looks nice and clean .
