Old 01-25-2010, 02:00 AM
russ67chevelle russ67chevelle is offline
Default anyone using nitrous?opinions?
lets spark a thread here...i havent used a ton of the stuff, but ive seen the gains and boy its addictive as h#%%!!!
seperate regulator big shot plate, 93 nitrous pill is biggest sofar ive used...
anyone else want to talk nitrous?
Old 02-03-2010, 07:46 PM
johnnys1977 johnnys1977 is offline
Al I can say from what I have witnessed. It is very hard on parts!
Old 02-05-2010, 01:02 AM
it can be, just like anything it MUST be respected, meaning if u load a stock motor full of a big shot of nitrous....power will always find the weak link, but if individual is educated on the stuff and knows what to do and what not to do....thats the trick
Old 02-19-2010, 11:53 PM
Mitchell Mitchell is offline
Indeed, however if used properly, in the right quantities and with the correct parts combo an engine can last over 100 thousand miles while using lots of nitrous on the weekends at the track.
SBC350
L31 Vortec Heads pocket ported with stock valves, Comp Cams N+L79-H, .462/.468 valve lift, 229/236 duration @.050, 112LSA, 9.6:1 compression, Summit Stage One Vortec intake manifold, Holley 600cfm street carb W/ vacuum secondaries
Old 02-20-2010, 12:02 AM
A stock larger displacement v8 should be able to take a 100 shot of nitrous consistently with no problem at all. There is one thing to be aware of though, nitrous loves to burn holes in cast pistons, however it is easily avoided, it's actually quite simple, never ever ever ever let it ping/knock even for a second while using nitrous with cast pistons. if you want to run more than a 100 shot you should really start thinking about forged internals. never run nitrous on a 2 bolt main small block, and if you are smart, you will build your motor with cheap insurance too (aka forged aluminum pistons) just in case it pings/knocks a little for some reason.
SBC350
Old 02-27-2010, 10:52 PM
all good advice! a big chevy crank will take more abuse than a sbc...i am biased,but it is a fact...
with all the info on nitrous on the internet, if one is careful and cautious it can be soooooo much fun
Old 03-02-2010, 06:15 PM
I just made a deal to trade my used turbo 350 for a new built turbo 400, I am planning on buying a B&M torque master 2400rpm stall torque converter and I think after that I should be able to run a decent bit of nitrous on my small block... someday IF I ever get any money.
SBC350
Old 03-21-2010, 01:53 PM
65chevelle 65chevelle is offline
My dad uses a 150shot in his '99 stang but every day he regrets not going with a supercharger or turbo. Would of been similar in price and wouldn't cost him 50-75 bucks for refills every night at the track along with systems frying and breaking... Also if your using it in a street car check the local laws, people tell him if he ever gets pulled over or in a wreck there is a HUGE$$$ fine here.
Old 03-23-2010, 08:09 PM
screw the local laws, they never ever ever look under your hood, not unless you do something stupid like let on to the fact you are using illegal stuff. another thing is idk where you get off saying nitrous and superchargers are the same price... I could set up an elaborate nitrous system for much less than 2000 dollars, and the cheapest supercharger i can buy is out of the box 2000 dollars, plus i'd have to make a few changes to my set up to get optimum performance from it, and it wouldn't give me near the increase in hp as a good nitrous set up would. last thing i have to say is if hes frying things he's doing something wrong... too much ignition timing, not enough fuel etc. something like that. or he's just running too much for his set up and needs to build the engine differently. (when building a nitrous motor it's all about heat management, this means proper exhaust valve timing is key, and good exhaust scavenging/flow, that's why most nitrous cams have wider LSAs and and higher intake centerlines, and they are almost always dual pattern cams with more lift and duration on the exhaust side)
SBC350
Old 07-27-2010, 01:54 PM
smokenjoep01's Avatar
This is my kind of thread. I use nitrous on my worlds quickest street ridden VRod. Going on its seventh season and havent had to adjust the valves yet. hundreds of runs a season in the hot southern climate. Its all in the set up. Looking forward to squirting my bowtie!
I HATE RUST!
