Old 10-13-2012, 08:37 AM
earthquake68's Avatar
Default Hand hammered panels
With the onslaught of thin, Chinese, junk metal repair panels, I've gotten better at making my own. I use 18 gauge steel for everything unless it needs to be structural. (ie: a stiffener for mounting something) Then I'll use 14 gauge.
This isn't a Chevelle, I'm just throwing out the fact with minimal tools, (in this case a flat body hammer and a 2" round length of pipe) you can get some pretty decent results.
Here's a compound curve in a wheel well arch I did.
...and here's the trunk pan of a '61 Bel Air I'm doing.
Before:
And after:
Also, if a repair panel isn't even offered, ...I have it. These are floors I did to mate a '66 Ford truck to an '85 Bronco chassis while using all the factory mounts for the Bronco interior and center console.
A piece of 18 gauge sheet metal that comes in 4'X8' sheets costs me $40. I can typically do two cars worth of repair panels with that, at least. Yes, it takes more time, but time doesn't cost me anything out of pocket. It also doesn't matter if a repair panel is hard to find or not. With a little time, I have every repair panel I'll ever need leaning up against the wall of the shop.
Alan
1964 Chevelle SS
Old 10-13-2012, 02:18 PM
Very impressive work.
Old 10-14-2012, 07:10 AM
X2! That's way beyond my skills.
Old 10-13-2012, 02:38 PM
You are quite talented ,you could probably do well just making panels for people in need .I hate the China made crap .
Old 10-13-2012, 06:37 PM
Thanks, guys!
I'll admit I cheat a little. I cut the rust out back far enough that I can cut just one large, intact piece of metal. Then I'll flatten out the metal and trace it out on the new metal. Then re-form the new metal to look like the old one. A little trimming to get it just a hair smaller than the hole it's going in, then I butt weld it in and grind it smooth so the repair is seamless. That's pretty hard to do without the car here.
I just bring this up as an alternative to expensive, inferior parts.
Alan
1964 Chevelle SS
Old 10-14-2012, 07:45 AM
Nice work!
I've done some of that type of stuff too. I've been working with 16ga on my Chevelle tunnel (thicker to add structural rigidity to the body). I think when I get back to 18ga, it's going to seem easy.
Old 10-14-2012, 08:23 AM
Originally Posted by Derek69SS View Post
Nice work!
I guarantee it will seem easier! Those couple of thousandths of thickness make a BIG difference when cutting and bending steel! Post up some pictures of the trans tunnel if you want.
Alan
1964 Chevelle SS
Old 10-14-2012, 09:01 AM
Trans tunnel big enough to fit T56 with engine raised 1" from stock location (helped with clearances for headers, oil pan, alternator, and A/C pump for LS1 swap)
Driveshaft tunnel behind it being mocked up:
I don't have a sheetmetal roller, so I had to do it all with shallow bends on a 4' brake.
Not much shaping going on there, but I did use the hammer a lot to make stuff fit.
Old 10-16-2012, 10:40 AM
Not bad at all! The hammer is your friend to close up stubborn gaps!
Alan
1964 Chevelle SS
