Old 02-26-2014, 01:35 PM
jcoffey411 jcoffey411 is offline
Default Need cam suggestions
71 chevelle 3400 lbs guessing
355
9.5:1 compression
AFR 195cc street heads 2.05/1.90
Performer RPM air gap
650 or 750 cfm carb have both
700r4 2600 stall
2.73 but 3.73 or 3.90 going in the spring
26" tire
Can not afford a roller so solid flat tappet it will be
Lunati recommended
30120741 Voodoo series
2600-6800
276/282
241/249
.520/.540
110/106
Comp has 4/7 swap
12-664-47
2400-6800
282 / 290
244 / 252
.520/.540
110 / 106
I ran the comp non 4/7 swap same spec in desktop dyno 2003 did not do as well as Lunati's grinds
Open to suggestions will be ran on the street or I would have ran Lunati's oval tight lash 2
30121102 which kicked the most in dyno simulation but for the street not so much
2500-6500
272/280
243/251
.530/.543051
106/102
Open to opinions and suggestions
Sent from my SPH-L720 using Tapatalk
