Old 06-22-2011, 09:23 PM
Default Ok i have a lot of questions with pics :)
ok guys and gals incase you didn't know i am learning about my motor so i took some pictures and questions that i am not sure of.
ok so what is this nut looking thing on the upper control arm
looking at this trans arm does this look right?
ok not sure but i know one is for the throttle cable and one is for the speedo cable right?
wiper motor?
not sure on this one but why is this closed up?
same thing what goes here?
Old 06-22-2011, 09:24 PM
the other side
and what goes here
Old 06-22-2011, 09:33 PM
what goes here? i know it runs to the water pump right?
what bolts here right under the intake bolt and over it
what about the two holes next to the water neck
Old 06-22-2011, 11:18 PM
I'll help with what I can...
Pic #1: I'm guessing that nut had some sort of a screw-in bumpstop as a travel-limiter. Not stock
Pic #3: top hole is throttle cable, lower hole (and adjacent round hole) were plugged on my car from the factory. Speedo cable comes through lower than those holes.
Pic #4: Yes, wiper motor goes there. There is a stamped bracket missing too
Pic #5: The upper plate shouldn't have a hole there... not sure why that's there. The lower (big) plate is covering the holes for the heater & A/C.
Pic #6: Should not be a hole there.
Pic #9: Square hole is where the fuse block goes
Old 06-23-2011, 07:12 AM
thank you for the info!!
Old 06-23-2011, 08:42 PM
Derek is the man !
Old 07-01-2011, 10:14 PM
ok what about this?
what goes here...lol
Old 07-02-2011, 06:36 AM
Second set of pictures.
#1, a hose nipple screws in, should look like the one in the back of the water pump. Small piece of hose connect the two.
#2, the 2 standoffs with tapped holes are for mounting a stock type ignition coil.
#3, hole on the right gets another hose nipple screwed in, heater hose goes to it. Other hole is extra, can be used to mount a temp sensor or plugged.
Last pic, is that the rear base of the carb? Vacuum hose to power brake booster.
Old 07-04-2011, 12:15 AM
Looks like there's an extra hole in the intake manifold too... put a plug in that hole unless you need it for a vacuum line.
Old 07-04-2011, 08:02 AM
Darn,late again missed my chance to be the man.
