Old 02-26-2012, 09:32 PM
Default my parts list for my chevelle!
MAN ITS LONG! this weekend after cleaning the garage and the shed and then cleaning around the car i made a master list of everything (i think i need) i need!
if you guys are bored and want to look over this list and tell me what you like and dont like or what i should change let me know
Chevelle master list
For the 454 motor to run
Wire the motor with the engine harness in the dinning room.
Lower Rad hose got it
Rad cap $15
valve covers got it
Thermostat got it
Belt for the water pump and alt got it
Radiator hose claps got it
Oil pressure sending unit $9.99
http://shop.advanceautoparts.com/web...RPSESWAMS_____
Coolant sending unit $8
http://www.autozone.com/autozone/par...9_77401_11499_
Fans got it
Coolant $20
Vacuum line from the dizzy to the carb
Battery $109
http://www.sears.com/shc/s/p_10153_1...rdNo=6#ppspecs
Fuel line from the tank to the pump got it
Air cleaner got it
Break in oil got it
Filter x2 got it
Oil got it
Suspension and chasis
Rear
Rear shocks got it
Rear brake rebuild got it
New brake lines for the rear got it
Parking brake cable got the ones that go to the brake shoes so far i need the ones that go to the brake pedal
Diff cover cleaned and reused my old one.
Front
New Springs $70.95
http://www.summitracing.com/parts/MOG-6330/
New Shocks $43.90
http://www.summitracing.com/parts/MON-5804ST/
Rebuild brakes done
Brake pads
Brake rotors
Ball joints
Upper $39.90
http://www.summitracing.com/parts/SUM-BJ-0195/
lower $79.75
http://www.summitracing.com/parts/AFC-20033LF/
(Tie rods $19.99-35.99 each)
Tires and wheels got it
Interior
Seat covers for front and rear
Dash Pad
Rear View mirror
Cargo tray (I think that is what its called
Pads for the front arm rest
New steering wheel
Turn signal arm
Exterior
Trim for the top of the hood
Gas cap
License plate holder $40
Front clip parts
Inner Fender wells both sides $200 most likely I will pick it up from NE chevelle
http://www.ss396.com/mm5/merchant.mv..._Code=RIF-68SL
http://www.ss396.com/mm5/merchant.mv..._Code=RIF-68SR
Exhaust from the header back. $349.95
http://www.summitracing.com/parts/FLO-17119/
and for my LS1 here is the
For LS1
Rear main seal $28
http://www.summitracing.com/parts/FEL-BS40640/
ARP crank bolt
Oil pan with pick up
LS1 dip stick
Flywheel
Clutch
Flywheel bolts $30.90
http://www.summitracing.com/parts/ARP-330-2802/
Pressure plate bolts
Bellhousing
Master cylinder setup
Slave cylinder setup
Driveshaft
Shifter
Intake manifold
Injectors
Fuel rails
Alt
Belt
Wiring harness
Pcm
O2 sensors
Headers
Exhaust
Fluids
Old 02-26-2012, 10:01 PM
Nice list of what you need. I bet there will be a few more things before you are done. Good luck on your project.
Old 02-27-2012, 07:48 AM
lol dont tell me that! if there is i didnt find it. you dont understand i spent about 2 hours looking EVERYTHING over on my car to see if i can find anything else that i need. now i am sure i am going to need some things to make it look better but thats not what i mean. i am talking about to get this car on the road that is what i need. i am hoping and praying that i dont need much more then whats on this list to get the chevelle on the road!
Old 02-27-2012, 07:57 AM
Do you have the following?
ENGINE
Fuel Pump
Fuel Pump Push rod
Fuel line from pump to carb
If Holley, carb fuel line kit
Thermostat Housing
Heater Hoses & clamps
Fittings for intake for heater hoses
Vacuum fitting for back of intake if necessary
Plugs, wires & distributor/coil
Throttle linkage brackets
Trans kick down bracket (if TH350)
PCV valve & hose
Breather for valve covers
Oil fill cap
Power steering? Pump, belt & lines
Exhaust (headers or manifold) gaskets & hardware
Starter
REAR
Gear oil x3 bottles
I have that same basic cover and when using the gasket mine seeped oil. I took it out and used a bead of sealant instead. Just an FYI.
I would get new rear wheel cylinders if you are replacing everything else in the brakes
Just a few items to think about.
Old 02-27-2012, 08:28 AM
I know I have an extra set of new moog springs in the garage. Let me look up the number on them. Their yours if you want to pay shipping if they are correct for your car.
Old 02-27-2012, 09:10 AM
ENGINE
Fuel Pump brand new and installed
Fuel Pump Push rod brand new from comps and installed
Fuel line from pump to carb i am using a 3/8 hose i didnt opt for the metal line
If Holley, carb fuel line kit yes its a holley and i did buy the holley install kit which came with everything
Thermostat Housing brand new and installed
Heater Hoses & clamps not running heat yet but i do have almost everything for the heater, this is something that i can do when the car is running but for now i am not going to run heat just for now
Fittings for intake for heater hoses i do have them in my tool box brand new from earl's fittings
Vacuum fitting for back of intake if necessary got it i just need to run the hoses which i have in my cabinet
Plugs, wires & distributor/coil brand new plugs gapped and installed brand new wires installed and hoping its correct brand new MSD HEI dizzy installed hoping its correct
Throttle linkage brackets i have it but its not installed
Trans kick down bracket (if TH350) super t-10 no need
PCV valve & hose there i am lost no clue where that is. i am not running an air pump should i?
Breather for valve covers i have them brand new just not installed
Oil fill cap got it brand new just sitting there waiting for the new valve covers
Power steering? Pump, belt & lines no power steering for now
Exhaust (headers or manifold) gaskets & hardware brand new headman headers long tubes with gaskets and bolts installed and ready to run
Starter brand new and installed ready to go
REAR
Gear oil x3 bottles i have 5 bottles sitting on my shelf ready to go.
I would get new rear wheel cylinders if you are replacing everything else in the brakes thanks i might take you up on that offer if unless i find a kit that comes with everything.
thanks a lot if the are for the front let me know! i have a brand new set in the rear already!
Old 02-27-2012, 08:53 AM
whew...what a list...
Old 02-27-2012, 09:25 AM
and thats not even including paint and mirrors and wheels and tires because i know i want 15s but i am not going to get them until i get the car on the road
Old 03-02-2012, 10:02 AM
just knocked off 3 things from my list let see if i can get about 3 more things..lol
Old 03-04-2012, 06:20 PM
Nice list, I'm going over mine now & will post it when I'm done. Mine will probably be longer because the guy who had my car slapped patches on all the interior floor pans & lord knows what he did to the body, I won't know that til the I knock down the rest of my list though. Lol. Get her going & good luck to you.
