Old 07-26-2012, 11:43 AM
lugnut76's Avatar
lugnut76 lugnut76 is offline
Default putting in a new engine need advice on trans
OK hears the deal my old 396/402 is toast. So I am having a local engine shop build a mild 454/425HP, good street drivable engine. rear gear 12 bolt rear end with a Moser posi and 373 gears.
(I did not install this it came on the car)
I have a 350 Turbo Trans with a 2500 Converter and shift kit. And I don't like how it shifts. From a dead stop just driving down the road it running up to 23-2500 then shifts HARD, not fun, so I have been manual shifts to get around this.
I am wanting to know what converter could I install or I also have a brand new 350 Turbo with no shift kit in the shop that I could use. Could I just swap the 2500 converter to that?
I don't have the extra funds to go a 400 or 700r route yet.
Thanks for any info/help
Old 07-26-2012, 02:05 PM
Try a governor kit from B&M to reprogram the shift points. But first try messing with the vacuum modulator. Remove the line, and back off the screw inside a half - to full turn. Then go drive it and see what it does. It might just need a simple adjustment.
