Old 07-21-2016, 10:36 AM
Default Jeep GC Steering Box?
Due to many different things I upgraded to the GC steering box. I have original hoses and an original pump. Other than these fittings is there anything else I need?
http://www.speedwaymotors.com/O-Ring...ter,24682.html
I'm going on vacation for a week and want to have everything ready to go so I can drive it when I get back. Do I need different hoses or bushings for the steering box?
Old 07-21-2016, 12:35 PM
Need different rag joint...Lares 200...found at Advance Auto...use discount coupon easily found online.
http://shop.advanceautoparts.com/p/l...200/18340125-P
I've done dozens of this swap...excellent upgrade for an A-body
Old 07-21-2016, 08:09 PM
I got the rag joint, thanks.
Old 08-15-2016, 10:25 AM
Got everything installed and the steering is much better. Need to flip the steering wheel 180 degrees, it's upside down now. Lines hooked up fine, just need to get the belt for the pump figured out.
Old 08-15-2016, 03:50 PM
Can't see how the steering wheel is now 180 off if it wasn't before...are you sure the rag joint isn't bolted together 180 off from the column flange??
Old 08-16-2016, 05:57 AM
That's what I mean, need to unbolt the rag joint and flip the steering wheel. My kids like to "drive" the car whenever they get a chance to get in so they were spinning the wheel like crazy while I had it unbolted. I thought I had it correct when I bolted it back up but I was wrong. Not a big deal.
Old 08-15-2016, 03:24 PM
Good deal. Glad to hear it is working.
Old 07-05-2021, 08:31 AM
One64SS One64SS is offline
I have a 64 Chevelle that I want to change to power steering. Can I ask what year steering box from a Grand Cherokee did you use and also what did you use for a pitmun arm
