Old 09-03-2020, 10:31 AM
67-ls1 67-ls1 is offline
Default Driveshaft tunnel project
I知 in the middle of a project to enlarge my driveshaft tunnel because my driveshaft was rubbing the floor.
My car is low but not that low. But I set my engine/trans up a little higher in the chassis because they both have big, deep pans.
I had already enlarged the trans section so this really pissed me off that I missed this detail earlier.
Here are a few pics...
ID:	4478   Click image for larger version
ID:	4479   Click image for larger version
ID:	4480   Click image for larger version
ID:	4481   Click image for larger version
Old 09-08-2020, 06:59 AM
Lot of work there, turned out pretty good.
Old 09-10-2020, 10:33 PM
Thanks. I知 kinda stalled right now because I知 electrifying a pedal car for my grandson.
Priorities.
Old 11-08-2020, 10:49 AM
Finally getting back to it.
Started bending up the tunnel sheetmetal, starting at the trans tunnel and working back.
Mostly tacked in to the front of the back seat.
ID:	4593   Click image for larger version
ID:	4594   Click image for larger version
ID:	4595   Click image for larger version
ID:	4596   Click image for larger version
Old 11-27-2020, 07:33 PM
Back on the project and close to finishing.
Driveshaft is back in.
Added Dynamat to the new tunnel
With the increased height of the new tunnel the carpet no longer reaches the door sills.
I cut the carpet up the middle and started at the sills and worked my way to the center. This way the seat and seat belt holes in the carpet fit again. I値l have a separate piece made to cover the tunnel where the console doesn稚 cover it.
ID:	4628   Click image for larger version
ID:	4629   Click image for larger version
ID:	4630   Click image for larger version
ID:	4631   Click image for larger version
Old 12-12-2020, 05:10 PM
All buttoned up....
ID:	4643   Click image for larger version
Old 08-10-2022, 04:04 PM
ycgoat ycgoat is offline
I am a novice fabricator, trying to mod the trans tunnel If I could trouble you with some questions.
What material did you use to raise the floor brace?
Are those hoops in the pics just attached to the floor sheet metal?
Old 08-10-2022, 10:57 PM
I’m a novice too. The hoops are 1/8” steel and are shoved down into and welded to the ends of the original floor reinforcement brackets that I cut out. I’m not sure if welding to the sheetmetal floor would be strong enough.
Old 08-11-2022, 11:03 AM
Thanks for the help, that makes sense and is with in my skill set.
