Old 08-27-2010, 07:32 AM
Warputer's Avatar
Warputer Warputer is offline
Default Yet another issue I found....and a question
While jacking up the rear of the car two nights ago, the right rear coil spring shifted 3 inches on the top side. While investigating, we found that we could move both springs out of the proper position with just the slightest tug, while the rear was hanging. Now, I am no expert but I'm guessing that this in not normal? This is a good sign that they are worn out?
Chris
69 4-Door Malibu
Old 08-27-2010, 08:56 AM
That sounds normal if the car is supported by the frame and the axle is hanging free.
Old 08-27-2010, 10:34 AM
Warputer's Avatar
Wow....that is normal?
Chris
69 4-Door Malibu
Old 08-27-2010, 11:24 AM
Dont take my word for it but they do hang fairly loose . Someone with more knowledge than me will chime in.
Old 08-29-2010, 12:05 AM
Rank Rank is offline
I havent checked out my chevelle but on my four-link 59 when jacked up there is no load on the springs but still not loose enough to come out of the spring pockets unless the shocks are removed .... the shocks keep the rearend travel from going so far as to let the springs be removed
In Warputers case all he has to do is catch alittle air going over a railroad crossing and he is going to have a major malfuntion .... something is wrong with his setup
Old 08-29-2010, 04:40 AM
Warputer's Avatar
Is it possible that the coil springs are normal but with a full droop of the rear, the aftermarket gas shock allows too much travel?
Chris
69 4-Door Malibu
Old 08-29-2010, 11:02 AM
Sounds like a possibility or the springs themselves dont belong under there.
Old 08-30-2010, 12:00 PM
I know my springs were loose with the rear hanging but the shocks were disconnected at the time. Not sure with shocks hooked up if it would drop that far.
Old 08-27-2010, 08:08 PM
ss1970chev454's Avatar
ss1970chev454 ss1970chev454 is offline
agreed. when the axle is hanging, the springs are loose. very easy to remove and replace.
TC # 4348
ACES # 6175
NCOA # 10479
"220...221 whatever it takes."
Old 08-27-2010, 08:52 PM
Warputer's Avatar
Thanks guys
Chris
69 4-Door Malibu
