Old 01-03-2010, 11:43 PM
OutCast's Avatar
OutCast OutCast is offline
Default Rear control arm upgrade
Just recently upgraded my stock rear upper and lower control arms to UMI adjustable uppers and tubular lowers. I was also in the transition between changing complete rear ends, so the pics I show will be complete re & re. If you are keeping your same rear end in the car, it is an even simpler process.
With the rear end removed, relocate new control arms and ensure good freedom of travel. In the case of the UMI arms, swab the bushing surfaces with the supplied assembly lube.
Elevate the differential into position with a floor jack and locate control arms with bolts. Install shocks and make sure springs are properly seated.
Ensure control arms fit and replicate stock items...
Install new lowers to mounts...
Using floor jack, elevate diff, attach uppers and lowers and shocks...
You are ready to go...
Old 01-04-2010, 07:00 PM
68bowtie's Avatar
68bowtie 68bowtie is offline
Looks good, i just picked up a used rearend cover like that. I'm also looking at the same lower control arms but with there new roto joint.
1968 chevelle ss(clone)355sbc a nice cruiser
Old 01-04-2010, 10:31 PM
I agree looks good.
Old 01-05-2010, 09:17 AM
Looks nice. I am also using the UMI stuff in ours. Can't wait to see how it drives.
Old 01-05-2010, 09:32 AM
Andy69's Avatar
Andy69 Andy69 is offline
wow, those are red.
How do the tubular lowers compare strength wise to the stock boxed arms?
Old 01-05-2010, 10:04 AM
Originally Posted by Andy69 View Post
wow, those are red.
I did the same on my '67...red powdercoated UMI upper and lowers along with the braces and both their F&R sway bars.
A good contrast IMO.
Old 01-05-2010, 12:47 PM
Herbie67SS454 Herbie67SS454 is offline
Wow. You guys are doing good.
Outcast: great pics.
Something for me to consider when funds get available.
Bill, I can't wait to check your 67 out. Lots of nice things happening to that ride from what I read.
Old 01-05-2010, 10:02 AM
OutCast's Avatar
They better be as good, or better. That's why I got them. I had boxed ones before.
Old 01-05-2010, 12:56 PM
Forgot to mention I have the same diff cover except it says DTS on it. Probably one manufacturer supplying most of the companies.
The way I look it at anythings got to drive better then the marshmallow ride we had with the drag springs in there.
Old 03-11-2010, 08:54 PM
christiansells's Avatar
christiansells christiansells is offline
looks awesome.i plan on going with the trz suspension front and rear.
reinventing the wheel one degree at a time
