Old 04-29-2010, 07:11 PM
Default Brakes pull on the Vette
64 with 4 wheel drums. All brakes are good with no leakage. Can't be rocket science,right? My tech says they need adjusted.
Old 04-29-2010, 07:25 PM
No it's not rocket science and adjusting the fronts would be where I would start. 64, may have self-adjusters, don't know when they started using them. Put it in reverse hit the gas then slam on the brakes, like lock them up. Try that several times first, if the adjuster's aren't frozen up that may do it. Otherwise try adjusting them.
Old 04-29-2010, 08:34 PM
Did you get the spinners off ?
Old 04-29-2010, 08:43 PM
Yes,how stupid was that?
Old 04-30-2010, 12:04 AM
Rank Rank is offline
Trust your tech, thats why they make the big bucks .... although it could actually be a fluid contaminated shoe.
Old 04-30-2010, 05:31 PM
The adjusters could be frozen, or it could have been driven very little and not backed up very often; I'd go over everything just to be sure and to have some peace of mind. Let us know, ok?
Old 05-01-2010, 06:46 PM
The only way to fix drum brakes is to remove them and install BIG discs.
Old 05-03-2010, 03:45 PM
Not all rims can be re-used with drum-to-disc changes ... clearance problems.
Old 05-05-2010, 03:03 PM
So Gary where is the picture of you driving the car with a big grin as wide as PA? I would say Texas but I don't want go get sued.
Old 09-17-2010, 10:11 AM
dbradley dbradley is offline
Like has been said, start with the fronts (very slight drag when rotating wheel). Another thing that's critical is air pressure in tires. A low tire (even just a couple of pounds) will amplify when you hit the brakes and load the tire.
If its pulling to one side when you tap the brakes, first thing I'd check would be ball joints. If pedal is low then comes "up" with a pump, brake adjustment.
Of course, I was out of HS when this thing was on the showroom floor new.........
