Old 11-21-2010, 01:27 PM
smokenjoep01's Avatar
Question Long or short water pump
Looking to find out how I determine if I need a long or short water pump for my 1972 - 307ci.? It has A/C and auto transmission. Plan on using a aftermarket flex fan.
I HATE RUST!
Old 11-21-2010, 07:35 PM
Rattler's Avatar
Rattler Rattler is offline
Are the accessories tucked up real close against the motor? long pump brings the accessories tighter into the motor. Short pump has accessories further away from block and uses longer belts.
To see what your current one is you can measure the distance from the surface that mounts to the block to the hub where the pulley mounts. Short=5 5/8" Long=7"
Old 11-22-2010, 08:23 PM
crankshaft crankshaft is offline
real close up to the timing chain cover is a short ,, distance between the 2 would be a long
Old 12-31-2010, 02:29 PM
dbradley dbradley is offline
'69 and later....... LONG water pump.
