Old 10-06-2011, 08:14 PM
GDwrench GDwrench is offline
Today after work I blocked down the primer I applied yesterday,and I used 240 grit exclusively.You can see some areas where I did not get enough material off before it was primed.It's hard too judge when your dealing with repair area of these size's not to mention a gradual curve with a negative radius of this length....can be somewhat tricky
But it did turn out nice after one blocking. I put three more coats of primer on the area's with some extra reducer in the mix so it lays a bit flatter/smoother for easier final sanding before the topcoats. If things go well I should have the custom mixed paint tomorrow and possibly spray color/clear tomorrow night
Here's another round of shots.............
ID:	1547   Click image for larger version
ID:	1548   Click image for larger version
ID:	1549   Click image for larger version
ID:	1550   Click image for larger version
Old 10-06-2011, 08:16 PM
I also got some primer on the rear gutter........
ID:	1552   Click image for larger version
Old 10-07-2011, 01:25 PM
Looking good. Love the color of the car. Can't wait to see the finished product.
Old 10-07-2011, 09:14 PM
Yeppers... I was always partial too this type of color,I even painted my Biscayne a color very similar to this. Don't get me wrong,I love black but all my previous hotrods were black and over time it gets a little old with the constant maintenance you have endure for it so I think it's a nice change for me... I'm diggin' it !!!
Ok, Daves Chevelle is in paint !!! I'm liking it, and if I'm liking it I'm pretty damn sure Dave 's gonna like it too I just got in and I'm pretty wipped so I will lay out a spread tomorrow with some explaining of what went down...There is plenty of pics so it will take a few posts too get them all in........till tomorrow
GD
Old 10-08-2011, 03:29 PM
Ok, I started with blocksanding with 320 grit(dry) on the reprimed area's and finished up by wetsanding the entire surfaces after that with 600 grit to get them nice and smooth/flat for the topcoats....
Next is to get the car dry and start to tape everything for paint.This is a very important process that gets overlooked by many.You want to make sure the tape is secure so that it does not come up during the paint process.Solvents in these chemicals tend to attack the adhesive on the tape making it lift so I keep an eye on this during the entire process of the job from having unesessary overspray getting under the car cover.
I use "jamb" tape in a couple locations so when the paint is sprayed here,it will go in "tapered" instead of having a sharp line.Usually after the job is complete you can hardly notice an edge.
I will be applying clear all the way down to the stripe so I use "fineline" plastic tape on the edge of that. Regular masking tape will tend too (bleed) through the edges and under,leaving a shitty mess.If you've done some painting at home using this you will know what I'm talking about...........
ID:	1559   Click image for larger version
ID:	1560   Click image for larger version
ID:	1561   Click image for larger version
ID:	1562   Click image for larger version
Old 10-08-2011, 03:44 PM
I don't have any sealer and frankly,I don't want to use it here cause we are to close to the doors.So what i did was to use the paint and apply two descent coats over the primer and allow that too dry and sand that down as to "seal" were the two different materials meet...If you don't do this you will see a funky line where they come together.
After this I apply another coat of the color and start to make judgement on the tint......it is too light !
ID:	1564   Click image for larger version
ID:	1565   Click image for larger version
ID:	1566   Click image for larger version
ID:	1567   Click image for larger version
Old 10-08-2011, 03:54 PM
They supplied me with some silver tint but that would have gone the wrong direction so what i did was end dropping in about 10 drops of "black" paint into the mix to "dirty" it up which helped alot from what we had,definately a step in the right direction. After spending some time at the edges of the blends ,it's time for clear.......
ID:	1569   Click image for larger version
ID:	1570   Click image for larger version
ID:	1571   Click image for larger version
Old 10-08-2011, 04:07 PM
Now from these shots with the clear you can see how i tried to stay away from the stripe,the front and rear of the panels, and away from the decklid on the tops of the 1/4 panels....very tedious stuff let me tell ya !! This color is very difficult.....In fact the mix we have is not a perfect match by any means but the way it's blended makes it presentable and thats what we're after here. Absolute perfection would be too respray the whole car and thats not going to happen.
ID:	1573   Click image for larger version
ID:	1574   Click image for larger version
ID:	1575   Click image for larger version
Old 10-08-2011, 06:57 PM
Looks very nice ,love to see work in progress pics like you have posted .Thanks for taking us along for the ride and send more pics.
Old 10-08-2011, 07:54 PM
Thanks John,had too take a break for a nap.My eyes started gettin' real heavy there !!
So I sprayed the car last nite and today I wetsanded the minor dirt nubs in the clear with a 2000 grit block thats available from Meguires...Now I do "just the nibs cause I want to leave the "orange peel".if I sand flat it wont match the rest of the car. After this I sand all the clear with 3000 grit under a foam pad and then polish with a machine.
ID:	1577   Click image for larger version
ID:	1578   Click image for larger version
ID:	1579   Click image for larger version
ID:	1580   Click image for larger version
