Old 12-11-2011, 08:45 PM
Just covered it up today, tired of looking at it without the motor in it. Most likely will be after the new year before I can get back to it.
Old 12-11-2011, 10:12 PM
lol i finally pushed the rear under the car. today now its on the jack under the car i think that will motivate me to bolt it up sometime this week
Old 12-12-2011, 09:51 AM
68ChevelleSS's Avatar
Well i finally made it back home! I took the cover off the 68 and have been tinkering with it a little bit here and there. Ordered a new set of back wheels for it with a different backspacing and also a new K&N air filter. Still have not figured out that dang squeaking noise!! Oh yeah, I sold my 72 to my Brother so now I'm down to one.
Boyd
Old 12-12-2011, 11:18 AM
I pulled the exhaust off the car, took the front & rear sway bars off and then dropped it off at the shop for the Motor to come out tomorrow.
I've got big plans brewing!
Old 12-12-2011, 11:39 AM
70SS396 70SS396 is offline
Cool! Are you going to tell us or is it a suprise?
Mike
Old 12-12-2011, 12:15 PM
No need for surprises!
Started a thread of my own for the build
http://chevelleforum.org/showthread.php?t=2393
Should be quite a transformation
Old 12-14-2011, 09:32 AM
Got the tires installed on the new back wheels. No more rubbing!!! I can actually lower the air shocks all the way down now! Also put the new air filter on. Feels good to be back and working on her.
Boyd
Old 12-14-2011, 03:52 PM
BBChevelle's Avatar
Pulled it out of the garage to pull the k5 in. Time to rebuild the auto hubs.
Fat fingered from the phone-Corey
Old 12-18-2011, 05:21 PM
Im about to move the Elky out of the shop so that one of our boys can get his Durango in to work on the brakes .I may just have to drive her to work tomorrow to check her out a bit.
Old 12-19-2011, 09:24 AM
i really need to bolt up the rear end this week sometime because my jack is under it and i need it to do other things...lol
