Old 08-03-2012, 11:18 PM
whitey's Avatar
whitey whitey is offline
Default motor mounts?
im doing an engine swap in my 71' chevelle. going from a small block to big block and was wondering if i'm going to need to shim my motor mounts or even purchase a different style or can i use the same kind i have for the small block?
Old 08-04-2012, 10:01 AM
You won't have to change a thing. Everything is the same, the frame mounts & the engine mounts. Just bolt it in.
Old 08-04-2012, 03:55 PM
whitey's Avatar
thats what i was hoping to hear. thanks man.
Old 08-05-2012, 12:47 AM
When you say a small block are we talking about a 307 or a 350?
The inside width (where the bolt goes through) on a 307 engine mount (not frame mount) is 2 5/8" ,while the 350/396/454 is 2 3/8".
While the 307 engine mount will fit over the 350/396/454 frame mount the opposite will not . The 307 engine mount is shorter than the 350/396/454 mount also.
Old 08-05-2012, 08:17 AM
Wonder why they did that? My father's 72' is a factory 307 car. The 454 went right in.
Old 08-05-2012, 09:06 AM
You can use either style, just have to match the frame mount to the engine mount. Don't mix one type frame mount and with the other type engine mount.
Old 08-05-2012, 07:16 PM
whitey's Avatar
its a 350 thats in there now and im dropping in a 454. hopefully it will be able to drop right in. cant wait cuz that bad boy dynoed at 530 HP.
Old 08-06-2012, 07:01 PM
Pull the engine mounts from the 350 and install them on the 454. Unless you want new mounts, then take the 350 mounts to the parts store and get a new set that match.
