Old 09-12-2012, 11:44 AM
Sounds more like a 4.10 gear, with about ~300rpm of converter slip.
If you have a high RPM stall converter though, it could be 3.73 with 550rpm of converter slip... hope you have a big trans cooler if that's the case.
Old 09-12-2012, 11:48 AM
Don't forget to allow for converter slippage. However, what the OP has for RPM vs. MPH would = excessive slippage. I am with you, needs to take it somewhere and have the speedometer certified.
Old 09-15-2012, 06:04 PM
whitey's Avatar
whitey whitey is offline
im not 100% sure about the gearing. and the speedo was used with a GPS. i just got the motor in and just need to work out a few bugs is all. I'll get er' right.
Old 09-17-2012, 12:35 AM
BBChevelle's Avatar
im runnin 3.55's and a 215/75 rear tire and im around 70 at 3k, 2700 is about 60-65. And as far as getting off the line, the straight tracks are mine from nearly 2 weeks prior to the picture. 213 feet and I just stabbed it on green.
