Old 04-23-2015, 07:39 PM
Hope its not soda blasting????
Old 04-29-2015, 08:51 AM
Got the parts back from the blaster.
They look good to me...and no they dont use soda.
Now its clean and epoxy prime.
ID:	3527   Click image for larger version
Old 05-02-2015, 03:21 PM
OH joy to the world.
Look what i found....how lucky i am....lmao.
Its fun for mick with pain time again....Dick n jane aint here .
Hmn...parts are ordered....i will start cutting when new metal arrives
The wife saw that and asked....mick are you ok....i was a tad wtf omg.
Wife says....carry on....its only money...and at least you will fix it right.
Will post more when i sober up.
ID:	3537   Click image for larger version
ID:	3538   Click image for larger version
ID:	3539   Click image for larger version
ID:	3540   Click image for larger version
Old 05-03-2015, 08:35 PM
I usually can read between the lines and figure things out. But boy you must have had a few. lol
Old 05-04-2015, 11:18 AM
I think he said Rust Sux ,not really sure though.
Old 05-28-2015, 03:19 PM
Default update on my project
Finaly got back to the chevelle.
The cowl panel would not fit in its welded together form.
So i seperated the two parts.....now its geting there.
The so called weld thru primer that the part came in was not under the welds
Perhaps thats what they do in taiwan....weld first ...weld primer after...lmao.
Anyway the drop downs are looking like they will work with a little body hammer work.
At this point at least every thing gets finished so rust wont come back in my
lifetime.
a few pics
ID:	3569   Click image for larger version
ID:	3570   Click image for larger version
ID:	3571   Click image for larger version
ID:	3572   Click image for larger version
Old 06-22-2015, 08:55 AM
Geting hard for me to get things done in the heat.
I instaled a canopy tent in the driveway to give a little shelter from sun
and hoping to turn it into a spray booth when the time comes.
Anyway i sandblasted the inner and outer firewall and lower piller area then shot
some epoxy.
Picked up a quart of semi gloss single stage to cover the primer with.
A few pics.
ID:	3585   Click image for larger version
ID:	3586   Click image for larger version
ID:	3587   Click image for larger version
ID:	3588   Click image for larger version
Old 06-22-2015, 10:55 PM
Looking good.
Old 06-24-2015, 11:51 AM
The semi gloss is a bit more glossy than i wanted so the paint store put some more
flatening agent in it today.
Good news is what i sprayed cant easily be seen...all inner structure panels.
Now its time to mock it up again and grind where the welds will be and spot with
weld thru primer.
ID:	3590   Click image for larger version
ID:	3591   Click image for larger version
Old 07-01-2015, 04:03 PM
more progress today.
the lower part of the cowl is welded in and the upper welded on top of it.
Then i ran out of gas.
All parts have epoxy primer and single stage matrix paint on them
Where the plug welds are were taken to bare metal in each individual location
and hit with 3M weld thru primer.
3M brushable seam sealer is the next step before it gets the side pannels
ID:	3599   Click image for larger version
ID:	3600   Click image for larger version
ID:	3601   Click image for larger version
ID:	3602   Click image for larger version
