Old 03-31-2014, 06:50 PM
Originally Posted by chevymaher View Post
Mine was where the sender strap grounded to the metal. It got loose on the rivet.
I went out and looked at that and it is bolt and not riveted on mine and will clean that to see if that works. Also noticed a gas leak at the rubber line where it meets the metal line so that has to be fixed as well.
Old 03-31-2014, 06:03 PM
I got it started and noticed that the gas gage is not working....it worked when I put it away. Any suggestions
Most likely the same reason the clock doesn't work.
Old 03-31-2014, 06:45 PM
Ha, Clock that does not work is in the Camaro and I think Tony did it to see how far he could push me.
Old 05-02-2014, 07:06 PM
Ray, I found this image online of a 72' W-code car without AC. The orange wire looks like the one in my engine bay - it appears to run to the heater box. (for the fan motor, I think?) Anyhow, I don't believe I need it, my car has AC. Not sure why they put that in my harness? It's an American Autowire harness IIRC. Now I am just down to the one black wire I can't figure out.
Old 03-31-2014, 07:34 PM
I didnt get my truck back today so we took the Malibu convertible out cruisin .
Old 04-03-2014, 11:49 AM
Im too busy playing with the truck right now so the Chevelle has to wait .
Old 04-03-2014, 01:29 PM
And that's a good thing !!!!
Old 04-03-2014, 08:25 PM
FINALLY!! after almost 2 months FINALLY!
now the fun starts tomorrow
Name:	side cowls.jpg
Old 04-04-2014, 09:44 AM
It runs! Have a fuel leak on both ends of the carb to pump line. (despite being tight) The tach wasn't working, just resolved that. And the key switch has issues... I will have to swap in the switch from the non tilt column out of the car.
Just the same... HUGE relief!
Old 04-04-2014, 05:52 PM
Congrat, always go to hear them run.
