Cool Ray...
Good Luck Shaun... As for my car....I wanted to drive it, but I wasn't home.
Just got in and it's after 11pm. Started working on the car around 1pm today. Here's the progress we made today. Hit a couple of snags, one I'm missing a rod that connects the reverse lock out to the steering column and the frame bracket. I'm also need to replace the clutch pedal rod between the pedal and the Z Bar. Hoping I can find what I need tomorrow. If I had the wiring harness I need and the parts above this car would be running tomorrow. I have to say thank you to may friend who is letting use his shop the next few days.
looks good man! congrats!
Had a new motor put in and just got the car back so today we are cleaning and waxing for a local car show on Sat.
Finally had time and agreeable weather to finish stripping the last control arm. I shot some primer on it and called it a day. I am off Sunday, weather permitting - I'll lightly sand it and shoot some paint on it. I still have over half of the front frame and cross member to strip, primer, and paint. Plus the spindles, steering arms, and calipers. I am worn out just thinking about it.
So cool. Hope you have a great time !
Got the control arm painted yesterday, will be painting the cross shaft and some other small parts today. I need to place another order to Eastwood. I am really liking the chassis black, hard to believe it lays down so smooth, and gives that kind of finish - from an aerosol can!
No new news to report, still waiting on an engine harness and a few small parts so I can finish getting the car running.
Managed to get out there early this morning before meeting my folks for lunch.
Installed an HEI rev limiter module today so I hopefully prevent any accidental over-revs.
Messed with the front & rear shock adjustments to get a little better ride quality for the street. Then went out and drove it!
Eric 496 cu. in. "cruiser" Assembled & tuned by Mo's Speed Shop - Dallas, GA |
