Old 01-13-2013, 01:57 PM
It's a Damn good thing you bought that roll back! What rear axle is under the car? 12 bolt?
Old 01-13-2013, 02:01 PM
Also glad I was only about 5 miles from home!
Has a 12 bolt (Eaton Posi, Moser Axles & Richmond 3.42 gear, 1350 billet yoke)
Summit's site is limited in doing a 3 series gear swap but I ended up ordering another Richmond gear, only this time it will be a 3.73 (now I can calibrate my speedo from a laptop!)
Old 01-13-2013, 05:55 PM
May I also suggest a girdle/support cover and axle tube braces. It's a heavy car with tons of torque.
I have an Eaton 4 series posi in my Chevelle with Strange 3.73 gears. I believe Strange offers 3.08, 3.42, 3.73, 4.10, etc for a 4 series carrier.
Old 01-13-2013, 05:56 PM
Eric ,sorry to read of your troubles with the rear end but the car looks killer on that truck .
Old 01-13-2013, 07:20 PM
Like one of these?
Been on there the whole time to help keep those main caps in place.
The car has a 3 series carrier - could have gone to a 4.10 gear (and may have been the better choice given the probability of putting in a T56 in the next year) but the 3.73 should be a decent gear for the track & highway with the current combo.
Yeah, it wasn't the end of the world and agreed, the car combo is not bad to drive around and still looks good! I debated getting the ramp truck painted the same color but not sure it would really look that good. Also though about reversing it and doing Forest Green strips on a cowl hood. May just leave it alone.... I do know A/C is getting installed before this summer!!
Old 01-13-2013, 08:58 PM
Forest green stripes on a cowl hood would look good ,I have a connection at AMD if you need it ,he can save you some money.
Old 01-13-2013, 09:52 PM
I took the top down and took it cruisin today .
Old 01-13-2013, 10:11 PM
Those covers help, but I feel you are getting flex in the housing and axle tubes.
Old 01-13-2013, 10:45 PM
started putting my drive shaft together, went to put the slip yoke in and boom wrong size had to return it and order a new one, hope to have it in by weds so i can put it together and put it in so i can work on my exhaust
Old 01-13-2013, 11:06 PM
Put a couple of extra traps over the car so when I cut some plywood in the garage the dust will stay off it, Hate having it covered up for winter.
