Old 10-15-2011, 08:42 PM
We went to the local cruise in and hooked up with Wild Bill ,and Dewayne and their better halves ,sure was good to see them. Also took Chase and his girlfriend for a ride in Joans vert.
Old 10-18-2011, 09:53 PM
so today i had about an hour to kill so i went to the garage to check on my rear end i wanted to find out what i had for sure. so i popped the cover off and here is what i found
4.11 gears with a Spool but then i found this
they are axles that can handle over 500ft tq so i think i will be good with these axles when i get the posi rear
so tomorrow if i can find another hour i will pull out the axle on one side and count the splines on my axle so i can order my new posi rear
Old 10-21-2011, 08:46 AM
pulled out my axle lastnight to see how many splines i have to order my new rear posi
Old 10-21-2011, 10:20 AM
Rharp Rharp is offline
I put new valve cover gaskets on yesterday.
I have a small oil leak that drips down from the front of the bell housing.
I have climbed under the car but could not locate the source.
When I stated looking around up top I noticed some moisture on the back of the valve cover, I figured what the heck I'll start there.
I'm not much of a wrench so I either fixed it or made it worse.
Rich
Old 10-21-2011, 06:17 PM
Boy you guys are busy. The only thing that I did today was talk about my car.
Old 10-21-2011, 10:29 PM
I went out to the shop and got the GPS out ,does that count ? All my time lately has been spent at the rental house trying to repair everything the previous tennants destroyed and spending quality time with our newly unofficially adopted boys.The boys are very fun and rewarding so I look forward to that ,the house not so much.
Old 10-21-2011, 10:59 PM
installed my new sending unit and gasket tomorrow i will install the gas tank and see if i can run a new line from the rear to the front
Old 10-22-2011, 09:00 PM
I looked at the Chevelle and El Camino for about 2 seconds then went to the renter house.
Old 10-23-2011, 04:53 PM
earthquake68's Avatar
I hobbled past it and looked at the body work I did a week ago. I have an engine to build, then I can get back to it.
Alan
1964 Chevelle SS
Old 10-23-2011, 06:15 PM
Drove the '67 again today...lovin' this Fall weather!!
Engine's running sweet...too bad it's coming out next month.
