Old 07-12-2013, 07:51 PM
Wow everyone has really been busy. John sorry to hear about the vert. You are still bringing it to the NOCC show.
Old 07-12-2013, 07:54 PM
It will be at the NOCC Show with or without carpet ,cant wait .
Old 07-12-2013, 11:48 PM
so i wired it i did everything and here the results
http://youtu.be/VWCdkzA3dvs
http://youtu.be/bJ-G0hLeYOo
something is missing from the steering column for some reason it seems like a shaft is missing to hit the ignition but we got it all wired and full exhaust i am so happy so far
Old 07-13-2013, 08:06 PM
Went to a car show today, only 12 cars showed up out of the 50 that had signed up. I have car shows the next 2 weekends to be at. Next week is our club show and the following weekend is my brother inlaws show that I helping also with. Next Friday I'm getting the pinion seal replaced and a front end alignment check done on the car before I drive it much more.
Old 07-13-2013, 08:11 PM
Wish I had the son of a bitch back.Yeah that's right
Old 07-13-2013, 08:18 PM
lol you know you dont want it
Old 07-13-2013, 09:13 PM
What did you do with grandsport ??? (But I am happy to hear this)
Old 07-14-2013, 06:51 AM
Had the windshield and rear window pulled the other day. Started cleaning the 50 lbs of crap from the pinch weld area. Some urethane, some butyl and some mystery goop, what a mess.
Old 07-14-2013, 07:20 AM
I used Butyl only with no urethane. I also had to use a special pinch weld primer before using the Butyl. No mess
Old 07-14-2013, 05:01 PM
A good glass shop won't use butyl to set a windshield. It's not approved and if the windshield pops out in an accident and someone follows it out of the car you can sue them if they did use butyl. From what I found Chevy did not use butyl on these cars although many people think they did. They used some type of adhesive and a cloth covered damn, maybe even butyl inside, to keep the adhesive from squeezing out where it's visible. Don't recall the name of products they used, that was over a year ago. A lot of the info was from guys that worked in the assembly plants back in the day.
A lot of people do use butyl rope and if the window pops out that's probably the least of your problems. Just stating what I found in my research.
