Old 10-21-2013, 10:04 PM
Glad you found it.
Old 10-22-2013, 07:05 AM
Originally Posted by fleming23 View Post
Found the leak. It was where it has always been. I pulled the drain plug and am going to let the oil drip out over night. Tomorrow I will sand it down and coat it with some good ole' JB Weld. Hopefully that will hold it over for the next week or two until the pan can be replaced!
This was about a minute after wiping clean.
It that damage from the header hitting the ground?
Old 10-22-2013, 07:46 AM
Yes. #1, they hang lower than I would like but are equal length primaries and #2, my front shock settings had the compression way too loose with the SB springs. If I would go through an intersection with a large dip at any high rate of speed the compression would sometimes smack the header on the pavement.
Old 10-22-2013, 08:45 AM
That's an easy fix, just slow down when you through a large dip, Lol
Old 10-23-2013, 09:07 AM
Sanded down the pan and plastered some JB Weld on the bottom last night. Will let it set up until tomorrow before filling and crossing my fingers! Felt very "bubba-like" and wrong using JB weld on my car....but it is only temporary.
In other news, I did get a rather nice package yesterday so may be that counteracts the negative voodoo from my oil pan fix.
Old 10-23-2013, 09:48 AM
new tank for efi?
i didnt work on my chevelle but i worked on the camaro. Installed a new e fan because my uncle wants to be like me..lol
Old 10-23-2013, 10:05 AM
Originally Posted by SS Shaun View Post
new tank for efi?
Yes sir! Wanted something that would not starve the pump.
Old 10-23-2013, 11:07 AM
how much? where did you get it? and does it use the stock filler?
Old 10-23-2013, 11:27 AM
Rick's Stainless
http://www.rickstanks.com/index.php
Prices start at a staggering $800 for carb'd applications and go up to about $1600+ depending on if you opt for the VaporWorx. Mine is not a VaporWorx but does have an upgraded internal fuel pump to a Walbro 400 liter per hour pump.
Mine was approximately $1300 shipped. It uses the stock filler location but includes an aftermarket, screw-on cap (haven't actually checked but this was discussed when ordering the tank) so hopefully no more fuel leaking out the back when full and accelerating. I could have easily saved many hundreds and went with a Spectra EFI tank but it seems that they still don't have the baffling worked out to prevent the pump from starvation when driving aggressively (even with the supposed update.) Had I been on a budget, I would mostly like tried the Spectra EFI tank.
Old 10-23-2013, 10:23 PM
Cleaned up the car for a friday night cruise in.
