Old 12-23-2012, 12:30 AM
Joshuataylor Joshuataylor is offline
Originally Posted by Jimmy View Post
Yesterday i noticed my dash light is not working. Can i change the leds bulbs without removing the dash and where are they located, has someone a pic of the 69 dash backside ?
the second problem is my fuel indicator. it allways looks like this.
is the sensor or the indicator damaged? is it possible to check the sending unit with a ohm meter?
I think there is no such way you need to remove dash
Old 12-23-2012, 08:38 AM
Thats a project on my 72 El Camino list ,anyone know the answer for Josh ?
Old 12-23-2012, 12:08 PM
I think Josh is trying to answer a question that was asked back on 8-12. On a 69 you have to pull the dash to change the light bulbs. And the fuel indicator was a ground problem according to one of the post. Before I would pull the dash I would check the light switch if the dash lights are not working first.
Old 01-06-2013, 11:23 PM
aristoman aristoman is offline
my 67 had a connector between the rear seat and truck that was partial disconnected. plugged it in completely and everything worked.
