Old 11-20-2014, 09:37 AM
Its a 70 with power steering.
Im thinking of removeing the drag link from the pitman and seeing
if I can move the pitman and box output by hand with the pump running.
The Cherokee mod is on the list of things to do but not till I find out why
I have such poor return from a left turn.
Old 11-26-2014, 09:19 AM
Decided to go with the jeep box.
Got the rebuilt box and new rag joint.
Now im searching for a metric o ring to AN adaptor fiting.
Not much luck at the local parts houses....perhaps jegs.
Old 11-27-2014, 09:11 AM
I drove down to the speed shop at muscle car city in punta gorda.
They had the fitings I needed.
Old 12-01-2014, 09:35 AM
LO and behold....the jeep box swap fixed my steering return problem.
Unfortunately I think the jeep box needs more pump pressure than the chevelle box.
900 lbs vs 1400 for the jeep.
The rebuilt jeep box has a little slop in it too...but I can return under warranty if I have to.
Now im into moding the flow valve on the pump for more pressure.
Old 12-03-2014, 09:52 AM
Got the control valve out of the pump.
It didn't have washers...only sealer on the nut.
So I measured the length with calipers and made it a tad shorter with a washer.
This helped take some effort out of the box...but I think a bit more
pressure is needed...so its getting a thiner washer next.
