Old 08-27-2014, 09:06 PM
not looking for oil pressure going up the roof i want the best protection and good oil pressure that is all that matters from me
Old 08-28-2014, 06:35 AM
Not sure how hot your summers are there, but you may find yourself switching viscosity by the season. My father ran thinner oil in the winter, thicker in the summer.
Old 08-28-2014, 06:45 AM
Van is garage kept and it does crank slower in the -25 degrees range when it is outside over nite because i using the garage. Durango is outside year round fires right up.
I had 230 thousand on the van when a oil cooler line broke forcing me to rebuild it. Parts were clean and looked like new so they must be lubricated well. It is the same engine now with 270 thousand. Bearings rings and gaskets. Durango has almost 200 don't use oil and runs strong. But honestly thinner would be better for winter. But I having incredibly good luck with anything i use this oil in. So if it ain't broke don't fix it.
Old 08-28-2014, 08:53 PM
yeah i was thinking of going to 15w-40 that seems to be the best
Old 08-28-2014, 10:23 PM
The guy who rebuilt my motor gave me a case of oil with it and said to run this "Joe Gibbs Driven HR-2 High Zinc Formulation 10W-30 for my big block
Old 08-29-2014, 12:39 PM
Gman Gman is offline
I've been using Brad Penn Grade 1 in 10W30 in my BBC, no complaints except I have to drive a little further to get it.
http://www.penngrade1.com/
Gary
Old 08-29-2014, 05:45 PM
I picked up some 10w-30 and seems to be good nice pressure seems good
