Old 09-12-2014, 11:54 AM
http://www.hotrod.com/techarticles/e.../photo_16.html
kind of like mine i guess?
Old 09-12-2014, 03:57 PM
Yup, they work. I would not take them off.
Old 09-12-2014, 04:30 PM
You can go back to stock if you want. You can buy a set of stock control arms, boxed or unboxed. You can probably find a set on Craigslist pretty cheap. They probably won't be boxed but you can buy the insert and weld them to make boxed set. You'll have to drill holes to bolt the sway bar on. If you go that way let me know, I'll find the link to a site that has everything you ever wanted to know about A-body control arms.
Or you can keep the current setup and add a sway bar if you want, looks like the arms you have are pre-drilled for a sway bar. I felt the ride was very harsh and improved a lot with stock arms. If you're okay with the ride, keep the arms you have. The lift bars do work well for what they're supposed to do, change the instant center and plant the rear end for traction. Stock arms due to the angle allow the rear to squat on launch.
Old 09-12-2014, 04:32 PM
Originally Posted by SS Shaun View Post
Yes, those are lift bars.
Old 09-12-2014, 07:55 PM
yeah i like the way it handles and ride. It grab the pavement with no issues when i step on it and i have no wheel hop i think i will leave it then. Now i just need to find a sway bar..lol
Old 09-13-2014, 12:48 AM
My father picked up a brand new 1" rear bar from a vendor on eBay. I believe it was under $100 shipped.
Old 09-13-2014, 12:55 AM
sounds good i will start my hunt in the AM or PM since i am going to bed at 2 am..lol
Old 09-13-2014, 06:01 AM
http://www.leverfamilysite.com/Boxin...ntrol_Arms.htm
http://www.leverfamilysite.com/Sway_...le_Spacing.htm
Old 09-21-2014, 10:55 AM
Pyasher Pyasher is offline
Has anyone ever installed a rear sway bar on a wagon? A heavy duty front and rear bar came with my 1972 Chevelle wagon when I purchased it.I put the front bar on and now the rear end feels loose. I also installed a set of rear boxed control arms. Pictures of a rear sway bar install would also be helpful to give me an idea as to what sort of parts I need to assemble.
