Old 06-25-2010, 10:33 AM
pat565 pat565 is offline
Originally Posted by 498 SS View Post
It would be better to tell me what you need for a 1967 or a big block.
How about a nice set of fenders?
Pat
70 Nova -More race car than not
67 Chevelle -Driver
67 chevelle -Soon to be Drag Week contender -If the pocketbook lets me!
Old 06-25-2010, 05:28 PM
Stock front sway bar from a 70 Malibu, 15/16", not the 1.25" bar.
Chrome 4 bolt rad top plate.
Unboxed lower control arms.
Some 70 headlight bezels.
Chrome top alt bracket form a 70 BBC.
70 307 emblems.
Everything is just driver quality but if you can use it it's yours.
Old 06-25-2010, 09:29 PM
On the top of my head I can think of.
1. Leaking heater core
2. 3 broken spark plugs
3. 1 cut spark plug wire
4. 1 broken body mount (just did that today)
5. A couple pounds of sandblasing sand that was under my carpet when I pulled it out.
6. A cheap yellow corvette model that I won at a car show..yeah Hank you were there at Bakers and was really jelous when I won it.
7. Assorted bolts (SAE and Metric) that held my inter fender wells in, I knew I was in trouble when I had to keep going from 3/8 to 10MM wrench to remove them. ( I went and bought the new kit from NPD)
I really need to clean up this mess.
Seriously, I have some stuff that I know others can use, I just have to go in attic and see what it is...
I have changed the engine harness and the front end harnes so if anyone needs any connector from them I do have them and they are yours if you need them.
Old 06-26-2010, 06:42 AM
Ric, do you have the plastic piece that goes on the end of the water temp lead? My sender has the post and the connector slips on from the side. I need the plastic cover that has an opening along the side where it slips on the sender.
Old 06-26-2010, 08:36 PM
Hank, I should have and will pull the harness down from the attic and see what I got.
Old 07-02-2010, 08:25 PM
Hank, is the green wire...I have one on my new harness but there is not one on my old harness that I can find..which is really wierd.
Old 07-03-2010, 06:26 AM
Yup, the green wire. Thanks for looking Ric.
