Old 05-01-2010, 06:46 PM
The only way to fix drum brakes is to remove them and install BIG discs.
Old 05-03-2010, 03:45 PM
Rank Rank is offline
Not all rims can be re-used with drum-to-disc changes ... clearance problems.
Old 05-05-2010, 03:03 PM
rak1's Avatar
rak1 rak1 is offline
So Gary where is the picture of you driving the car with a big grin as wide as PA? I would say Texas but I don't want go get sued.
Old 09-17-2010, 10:11 AM
dbradley dbradley is offline
Like has been said, start with the fronts (very slight drag when rotating wheel). Another thing that's critical is air pressure in tires. A low tire (even just a couple of pounds) will amplify when you hit the brakes and load the tire.
If its pulling to one side when you tap the brakes, first thing I'd check would be ball joints. If pedal is low then comes "up" with a pump, brake adjustment.
Of course, I was out of HS when this thing was on the showroom floor new.........
