Old 05-21-2010, 05:57 PM
I cycle shoes like Cary. New, have to break them so they don't look brand new. Then every day use. Then work around the house use. I have one pair of white mid-high tennis shoes I've had for... I don't even know how long. They're perfect, I keep them in the garage right next to the door from the house. Don't lace them up just slip them on when working on the car. Slide them off when I come in the house.
I have work boots, several pairs, dress shoes, several pairs, but mostly I were sneakers or slip on moccasins. Since I work from home fashion is not all that important.
Hey Gary, did you get your temp gauge problem fixed? That's the only thing not working with my new dash and gauge conversion.
Old 05-21-2010, 07:42 PM
Hank,my future son in law is an electrical genius along with his computer skills at his job. He is just waiting for me to be in the mood to tear the dash out to fix it. In the meantime the amp guage quit working along with the dash lights,which half worked last year.I just got a new printed circuit,the best this time, and we will tear into it in the next couple of weeks. Those dam helicopters screwed me up,so I am behind schedule. I will keep you posted.
Old 05-21-2010, 08:09 PM
Helicopters! That's why my car isn't done yet.
Amp gauge, dash lights and temp gauge? Unless the printed circuit went up in smoke I would be surprised if that was the problem. Pull the dash pad and make sure the harness connector is plugged into the gauge pod all the way. That's the only thing that should cause all 3 to go except for a total meltdown of the printed circuit. I'll let you know if, when, I find out what's wrong with the temp gauge.
Old 05-21-2010, 08:23 PM
Everything else is good,I'm thinking grounds?
Old 05-21-2010, 08:37 PM
Maybe, but not the amp gauge, no ground there. It has 2 connections, one to the junction block by the battery and one to horn relay, main splice area, no grounds.
Old 05-21-2010, 08:40 PM
It quit all of a sudden,so maybe I'll get a new guage before we rip everything apart?
Old 05-21-2010, 09:15 PM
Rank Rank is offline
I wouldnt wear 'em till they are worn in alittle .... know what I mean?
