Old 09-20-2014, 05:34 PM
Wow that is rough from behind the doors back. Damn shame, another one bites the dust.
Old 09-20-2014, 06:06 PM
Yes but that is why i got it cheap. Only thing good is exactly what i needed. And nothing else.
Old 09-21-2014, 07:21 AM
Well out to gut the Elky so it can go By-By as quickly as possible.
Old 09-21-2014, 03:51 PM
Making a winter to do list today. Looks like I will be tearing the car apart this winter again. Not looking forward to it.
Old 09-21-2014, 04:24 PM
Got the doghouse stripped. Gauge cluster and venting out. About another day and it be ready to ship to Hot Rod Heaven.
Old 09-21-2014, 07:53 PM
What are you doing that you're going to have to tear your car back apart this winter?
Old 09-21-2014, 07:56 PM
What all parts are you salvaging out of it? Does it have the SS or Malibu dash?
Old 09-21-2014, 08:13 PM
Dash is coming out, temp gauge and tach stop working. Im sure it's not a ground issue, and the tach worked funny when I got the car running and now it doesn't work at all. I also noticed yesterday the heater control plate cracked across the middle of it. The motor is leaking oil badly now. Not sure if I will have to pull it for a rear main yet or if it is a valve cover or the intake. I find no oil up high on the motor. Im hoping while the dash is out I can find an original dash bezel and replace the repro one. while it's out I will also get the radio working and finish installing under the dash lighting. Car only has 380 miles on it since I started driving it 3 years ago. I would drive it more if I wasn't leaking the oil under it.
Dash work
Motor oil leak
Might also put in a new wiring harness and fuse box while I have it apart again.
Old 09-21-2014, 09:10 PM
No it is a El Camino. I getting all the air conditioning vents, evaporator and condenser,all the underhood valving for the air. I needed a decent steering wheel to restore. Since 68 wheels were garbage basically for cracking, and there are no aftermarket wheels the horn button works with.I snatching the power steering for a back up. I needed the front sway bar. I needed one headliner rod, they dont make them either. Basically I needed a bunch of oddball 68 stuff they don't reproduce. So this bent in half car was perfect for my needs. I was just about to buy a running car to get this stuff off of. Better a total than trash a good car for the parts I needed tho.
I buying all new dash parts that they make that show for the SS stuff. Emblems and dash placard bezel etc etc. It was a 327 2 speed originally. I suspect the engine and trans were in the old chevy truck the guy had there. 327 in a 60 custom truck HUMMM wonder where that came from?
Old 09-21-2014, 09:58 PM
Looks like it has some usable parts on it. Doors, front clip, trim parts, etc
