Old 05-20-2013, 08:35 PM
I have help lined up for saturday but I hope to have most of it done on friday ,Im going to be at Home Depot at 7 AM friday morning to rent a trencher and get started soon after .
Old 05-20-2013, 09:57 PM
Im going to use 1" pvc with 2 short runs of 3/4" ,I dread it ,my place grows rocks something aweful. I plan on about 18" deep .
So is PVC pipe legal in your area for drinking water? We can use the flexable plastic pipe that comes in a roll that is marked safe for drinking water use, but not PVC.
Old 05-21-2013, 06:32 AM
CPVC is okay for hot/cold water supply, that's the off white/yellow stuff. PVC for drains and cold water supply but not hot. I'm sure Tony would know better and codes may be different in different areas.
Old 05-21-2013, 06:38 AM
PVC is used for DWV systems (drain, waste, vent). Like Hank says, CPVC is for domestic water supply.
Good luck on the project John. I know that is going to be a big job.
Old 05-21-2013, 08:46 AM
White PVC is legal here ,CPVC for hot ,but you can really use whatever you want as there is no inspection .I chose PVC because its easy to repair if needed .
Old 05-21-2013, 08:14 PM
John, you just make sure you don't over do it. I hope you have some help.
Old 05-21-2013, 08:42 PM
One of my nephews has decided to take a vacation day on friday so I have help now .That should make it much better for me .
