Old 10-10-2012, 04:27 PM
Okay, had to go back and read the entire thread. You've replaced the fan clutch, thermostat, rad was checked out, base timing is at 16*, hoses are good. No vacuum leaks, it was mentioned, hope you checked that out. Not a lot left.
Only other thing I can think of is the vacuum advance. Is it working? Timing and engine RPM should jump up when it's connected, compared to disconnected with hose to carb plugged. Also where is it connected to the carb, near the base or up above the throttle plates? If it's up top I would move it down to a fitting near the base of the carb.
If you use a infrared thermometer check a few different places, front of head, lower on the block, center of head on the side. Then temps will vary some but should give you a good idea of what's going on.
Old 10-11-2012, 10:05 AM
70SS454's Avatar
70SS454 70SS454 is offline
I'll check that Hank. That's for your help.
Dan
Old 10-16-2012, 03:37 PM
John's Avatar
John John is offline
I personally at this point would be wondering about the water pump and radiator.
Old 10-16-2012, 05:34 PM
Hank, there are a few infrared thermometers out there. Do you have one that you suggest ?
Old 10-16-2012, 05:42 PM
Not really, like you said there are quite a few. Fortunately the internet let's you find reviews on just about anything or maybe someone else has a suggestion.
Old 10-18-2012, 01:15 PM
70SS454's Avatar
I am actually thinking about replacing the water pump. It never hurts to have a new one and it could be the culprit.
