Old 06-12-2012, 06:24 PM
BBChevelle's Avatar
After 4 months of neglect I finally pulled it out adjusted the carb and went for a ride. Came back and took the doors apart to clean and lube the locking mechanisms so I can put the poppers and solenoids on I've had for 5 years in the tool box. Gonna be nice to push a button and have the doors open up.
Fat fingered from the phone- Corey
Old 06-12-2012, 06:46 PM
With the new hydro-boost set up coming and now that vacuum is no longer of importance, I made a call to one of the popular camshaft makers with some proven combos over on TC.
Chris Straub is designing a new cam for the 496 that according to him may not give me much more in the way of peak power but said it will be much more noticeable across the power range and give me a power band that is 5-600 RPM greater in both directions. Duration should stay pretty close to the current 240/244 but will be on a 107 LSA vs the 110. Everyone who has a Straub stick seems more than pleased with it so I am hoping for good things!
"Hi. My name is Eric. I am apparently never satisfied with the current state of my Chevelle"
Old 06-12-2012, 08:33 PM
Picked my car up today and drove her home. YEAH !!!! What a joy it was getting onto the e-way and giving her a little gas. With the EFI it turned right over, I had to give it one little pump on the gas pedal to keep it running, she was cold, after that it ran like a charm. It was so great hearing the roar of the engine and just driving my car.
Now it is time to give my car a good cleaning, probably in the next few days.
Old 06-12-2012, 09:03 PM
After driving home from CB12 in the rain ours needs a lot of cleaning ,not sure when that will happen. I washed and vacced the 96 Explorer and got it looking good and put the for sale signs on and it gets parked at the top of my driveway after work tomorrow .I already had one person interested in it so we will see what happens ,it is going cheap.
Old 06-12-2012, 10:22 PM
My wife gave me some time alone today so i was finally able to finish my rear drums all i need are the actual drums and brake lines and fluid for the rear diff and the rear is just about done. Tomorrow new shocks are going in and i hope to wire my motor
Old 06-13-2012, 09:53 AM
In about 4 hours I will be putting my motor in, and if all goes well the new wiring harness will be here tomorrow.
Old 06-13-2012, 10:36 AM
nice!! i am going out in about 3 hours to put my new shocks on and spring isolaters in place
Old 06-13-2012, 08:54 PM
brakes are done all i need are the drums
tomorrow i will wire the motor and see what happens
Old 06-13-2012, 10:34 PM
Cool Ray...
Good Luck Shaun...
As for my car....I wanted to drive it, but I wasn't home.
Old 06-14-2012, 01:18 AM
Just got in and it's after 11pm. Started working on the car around 1pm today. Here's the progress we made today. Hit a couple of snags, one I'm missing a rod that connects the reverse lock out to the steering column and the frame bracket. I'm also need to replace the clutch pedal rod between the pedal and the Z Bar. Hoping I can find what I need tomorrow. If I had the wiring harness I need and the parts above this car would be running tomorrow. I have to say thank you to may friend who is letting use his shop the next few days.
