Old 05-25-2010, 07:30 PM
Mike 1972SS's Avatar
With the pistons that are installed, I would pass. Even if you had 76cc heads, the compression ratio would be almost 10.4:1, which is pushing it on premium pump gas/aluminum heads.
What is the combustion chamber size on your heads? Are they cast iron or aluminum? What cam are you going to run? More info needed.
Mike
1972 Chevelle SS
