  #12
Old 06-18-2010, 06:31 AM
Looking good Ray. That wiring harness sure is a nightmare to look at isn't it.
Make sure you put some weather stripping around the vent housings before you slide them into the ducts. Just about impossible to get it in after the dash is installed. I forgot to but had to drop my dash again to get the temp gauge working so I did it then.
Are you going to black out the 4 small pods? I used SEM landau black on mine, perfect match, you can't tell I sprayed it.
