  #24
Old 09-30-2010, 07:05 PM
I may have found the problem with the loose steering, and it was a cheap fix. The steering gear box connects to a bell crank bolted to the frame rail. There is another bell crank on the passenger side that serves like an idler and also attaches to a steering stabilizer.
So while my son cranked the steering wheel side to side I watched the front suspension. At first I thought the bell crank support bearings on the driver's side were shot. From another angle I could see it was the frame rail twisting top to bottom. There is a cross-member between the frame rails right at the bell crank supports. The bolts that attach the cross-member were loose on the driver's side. Tightened them and anything else I could get a socket on and no more flex in the frame rail.
I don't think it's really a permanent fix. The bolts that hold the cross-member aren't that big. If it's better but works loose again I'll tack weld the cross-member to the frame rail. I can always cut the weld if the cross-member ever needs to be removed.
I feel a lot better now. The bell crank supports on these chassis are known for wearing out. This motorhome already had new ones installed, Henderson Super Steer bell cranks with tapered roller bearings, about $300 a piece. I didn't want to have to replace those again.
I know you guy's don't give a shit but I thought I'd share anyway!
