Here's one guide I used from Robs site http://www.1969supersport.com/
rear brake backing plates etch prime gray #sxa1031 and eastwoods detail gray front control arm shafts napa zincrom primer #7222 and napa iron/block cast #7250 rearend cover etch prime gray #sxa1031 and sema promax #61023 semi gloss black contol arm shims #sxa1031 and eastwood detail gray tie rods napa zincrom primer #7222 and napa iron/block cast #7250 tie rod clamps #sxa1031 and eastwoods detail gray steering gear box napa #7222 and napa #7250 steering gear small cover eastwoods silver cad steering gear ring and nuts sem promax semi gloss black driveshaft straps and bolts #sxa1031 and eastwoods detail gray front wheel grease cups #sxa1031 and eastwoods detail gray ends of drive shaft #7222 and #7250 universal joint clips and clip area plasti-cote clear, small bottle brushed on transmission #7222 and # 7250 transmission side cover eastwoods silver cad driveshaft plasti kote non sandable primer and eastwoods detail gray hurst shifter plate valspar antirust flat black front springs sxa#1031 and eastwoods detail gray front stabilizer bar sxa#1031 and eastwoods detail gray rear springs sem #15031 landau black flexible paint
