Welcome to the forum mm. Not sure what the 605 box is. What do you mean without moving the old gear box? A lot of people have used the gearbox out of Grand Cherokee. It has a better turn ratio, the hose fittings are different but otherwise it's the same Saginaw gear box. They also make a power steering gear with improved ratio that is a direct swap.
