Old 07-02-2011, 07:36 AM
Second set of pictures.
#1, a hose nipple screws in, should look like the one in the back of the water pump. Small piece of hose connect the two.
#2, the 2 standoffs with tapped holes are for mounting a stock type ignition coil.
#3, hole on the right gets another hose nipple screwed in, heater hose goes to it. Other hole is extra, can be used to mount a temp sensor or plugged.
Last pic, is that the rear base of the carb? Vacuum hose to power brake booster.
