#11
I got the engine in with the correct oil pan so no more hitting the crossmember which is a good thing. I was able to get it together with the new flywheel, clutch, and bellhousing. I chose to go with the Valeo diaphragm clutch and new GM flywheel. This weekend I went to a swap meet and bought an oval port intake manifold to get rid of the low rise cast iron one that is on it. I'm probably going to rebuild one of my Holley 4150's with mechanical secondaries too. My biggest issue was header fitment on the drivers side. I had to pull the steering shaft out of the car and jack up the engine again with the temp sending unit out of it and the oil filter off to get the damn thing in there. The good news about the headers is I know they'd fit in one way or another because I had everything mocked up in the other car before I dropped the 400 back in it. It turns out the Z bar I got for the clutch linkage is incorrect but it shouldn't take much at all to make it fit until I track down the right one. I got the M20 under the car and took out the bolts for the shifter but left the mounting plate on. I'm going to figure out what has to be trimmed from the tunnel for the shifter to clear and then I'll spot weld the shifter hump in place.
1970 Chevelle SS396 project with 454/M20 ps,pdb,U14 gauges, rear defroster 84 K5 Blazer 350/SM465 75 K5 Blazer 355/SM465/8 lugs |
