Old 05-18-2012, 02:46 PM
In the photo I posted you can see where the paint was applied on the lower a-arm mount and where it stopped, likely because of getting over-spray on the motor. Then on the frame rail it appears have paint and then stop. It is a common thing to see quick flips but not necessarily indicative of the rest of the car. Just something to keep in mind. It may not even be the case but just another reason to carefully inspect the car in-person.
Another photo.
Look at the rear coil spring and brake drum (plus all the hardware is painted black) Again, this doesn't mean the car is not worth it, just that it could have other short cuts.
I am no pro and am not trying to persuade you for or against this particular car.
