Old 02-12-2013, 04:44 PM
If the key is turning the ignition tumbler it is the correct key.
As you mentioned...using the key, turn the ignition switch to ACC...then insert the end of a paperclip into the hole on the tumbler face while continuing to try and turn the key past ACC.
The lock assembly should pop out.
