Old 06-13-2013, 05:28 PM
aidenj454 aidenj454 is offline
Default brake pedal still seems to low feels like only the fornt discs are working
I'm new to your forum ,hoping you guys can give me some advise.my 70 el camino has front discs, they look stock but I'm not sure and drum rears, I replaced master cylinder calipers,rotors, drums shoes,wheel cyls, spring, adjusters and rear end brake lines. I have bleed the brakes multiple times with vaccum bleeder, power bleeder, and even tried speed bleeders. The pedal still seems low, while out for test run, it seems like I only have front brakes. The rears have bled fine ,fluid flow, even gravity flow What have I missed? Only thing I haven't done is to bleed them old school way with two people. Could it be as simple as that?
