Old 06-30-2014, 06:16 PM
... Like yours it's steel H beam. I think it weights around 300 lbs, so I'm going to need a little help getting it into place.
You think? You can rent a hand crank forklift to raise it. They used two to raise ours but it was over 700 lbs. 300 lbs isn't as bad but still a lot when you need to lift it over a few feet. Good luck, be careful.
