Old 12-31-2014, 11:51 AM
Pyasher Pyasher is offline
Mr. Gasket #106 is the closest port size to the Edl-1205 but is .120" thick.
Will work fine...
http://www.summitracing.com/ga/parts/mrg-106/overview/
Thanks - I will be ordering it today...
Old 12-31-2014, 12:22 PM
If your block has been decked, that means now the heads are sitting a little lower and farther out than stock on the block. By machining the intake you will undoubtedly almost double the offset of everything ie: bolt holes, port alignments and so on. Do like Bill suggests and use the afore mentioned gaskets.
I'm a retired toolmaker and I know what I'm talking about as far as machining metal to try and make fit.
Old 12-31-2014, 12:33 PM
Bill, Mestorod and Ken;
Thanks for the advice...
I will be installing the gaskets Bill recommend and the permatext sealant mestorod recommended.
Old 12-31-2014, 12:59 PM
Ditto...36 years before retiring two years ago.
Old 01-01-2015, 11:37 AM
44 years retired in 2008.
Old 01-01-2015, 01:47 PM
You can also go to the Edlebrock site and get the torque and sequence for that manifold if you don't already have them.
