Before anyone can give even a ballpark number, some things must be factored in. Compression ratio, valve size, flow numbers for the aluminum heads, camshaft profile, which exhaust system will be installed. Will it be a stock stroke crankshaft?
Wow, 17K original miles? What's the backstory on your car? Sounds interesting. Good luck with the build! |
